Import assemblies into teamcenter (2D and associated 3D)
I was able to import a 2D and associated 3D model from native mode to TC10 with NX10
But not with TC10 and NX8.5
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.fr
RE: Import assemblies into teamcenter (2D and associated 3D)
It will work with NX 8.5, but the old import dialog makes it more difficult than it should be.
The exact steps to take depend on what naming rule you are using, but in general you want to import the model and drawing at the same time. When the "output name" dialog pops up for the drawing (during the import or dry run), change the part number and part revision to those of the model, change the type to specification, and enter a part file name for the drawing.
www.nxjournaling.com
Might be that the usage of Specifications is blocked in your Teamcenter Environment
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
