how can I get step files from NX with the assembly structure ?
I want to get step file from NX with assembly structure[model tree], to be used in Catia V5. is it possible ?
RE: how can I get step files from NX with the assembly structure ?
From within NX, export STEP and select Entire Part from the dialog. Just to be clear, assembly structure is NOT the model tree - that would be the features used to make each model, which obviously won't be included in a neutral file translation like STEP, IGES or DXF.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
thanks.
I hope annotations will also be exported to step file, will give it a try.
