Limitation on seam welded API 5L pipes for high pressure piping chapter IX:ASME B31.3
Hi forum members
Reference: ASME B 31.3 chapter IX, table k-1, allowable stresses in tension for metals for chapter IX.
Material spec. API 5L Gr x42 to x80.
Note 6: this type or grade is permitted only in the seamless condition.
Query
1) For high pressure piping chapter IX of ASME B31.3, code restrict usage of seam-welded API 5L spec pipe. But why such limitation.
2) if such restrictions are to be overlooked what necessary precautions shall be taken(change in API 5L spec./ other technical ).
Thanks in advance
P.S changed query number 2 after looking at first answer
Query
Thanks in advance
RE: Limitation on seam welded API 5L pipes for high pressure piping chapter IX:ASME B31.3
2) Make sure your name doesn't appear on any drawings or documents... If you don't follow the code then you can't take credit for it in the event something goes wrong
If you don't like the restrictions, try and find another design code to use which does allow it, but probably has other onerous clauses...
