Multiple Ordinate Dimensions for Filleted Slots
I wanted to create the multiple ordinate dimensions for attached plate which has Slots and the corners are filleted .
When am trying to place the ordinate dimension by selection the element by window selection method its placing the dimension for all the fillet center points.
How do i control this.
Am attaching a sample output and model file as well.
Manikanda
RE: Multiple Ordinate Dimensions for Filleted Slots
I'm going to go out on a limb with a suggestion - after windowing, deselect the arcs to which you do not want to dimension.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
