Cycle with selection of objects
Hi all!
I have another question for you: I am currently trying to write a piece of code in NX open VB that performs these operations: (once again, I am a beginner)
- Open a part (DONE)
- get the collection of the STLs of a part (DONE)
- cycle through every single STL and ask the user to select a corresponding surface
- store in two separates array or in some other kind of structure the corresponding STL/surfaces (I am interested in the coupling of STL/surfaces)
I am trying to build it using the SNAP blocks, as in this example, but I have serious doubts that is the most efficient way. Any suggestions?
Thanks.
CODE --> VB
Public Class MyProgram
'missing the IMPORT/OPENING OF CAD PART
    Public Shared Sub Main()
Dim facetbody_collection As NXOpen.Facet.FacetedBodyCollection
        facetbody_collection = workPart.FacetedBodies
        Dim single_STL As NXOpen.Facet.FacetedBody
        Dim block_selection As New deviazione_STL
        Dim list_STL As NXOpen.Facet.FacetedBody()
        Dim list_SURF As NXOpen.Features.Feature()
        Dim counter As Integer = 0
        'inizia il ciclo di selection STL e SURF abbinate
        For Each single_STL In facetbody_collection
            single_STL.Highlight()
            block_selection.Show()
            'list_SURF(counter) =
            single_STL.Unhighlight()
            counter = counter + 1
        Next
    End Sub
    Public Class deviazione_STL : Inherits Snap.UI.BlockForm
        Dim selectionblockSURF As Snap.UI.Block.SelectObject
        Public Sub New()
            Me.Title = "Abbina STL evidenziato alla SURFe di interesse"    ' Text to be shown in title bar of dialog
            Me.Cue = "Seleziona la SURFe del modello CAD abbinata all'STL evidenziato"            ' Text to be shown in the cue line
            selectionblockSURF = New Snap.UI.Block.SelectObject("Seleziona la SURFe abbinata", "Seleziona STL2")
            selectionblockSURF.SetFilter(Snap.NX.ObjectTypes.Type.Feature)
            selectionblockSURF.AllowMultiple = False
            Me.AddBlocks(selectionblockSURF)
        End Sub
        Public Shared Sub OnOK()
            Dim selection As NXOpen.Features.Feature
            selection =
        End Sub
        Public Sub OnApply()
        End Sub
        Public Sub OnUpdate(changedBlock As Snap.UI.Block.General)
        End Sub
    End Class
End Class
