The volume of sea chest
Hello.
Can you do me a favor?
I want to know how to calculate the volume of sea chest? Can you show me please?
Thank you very much and have a nice day.
RE: The volume of sea chest
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
TTFN
There's part of you answer. Another part is what are your needs? I presume the sea chest acts as a reservoir to allow timed release for cooling or firefighting or whatever. Figger the time of need and the rate of use for that need and compute the volume from there, with a reserve. Like Civils do with detention/retention ponds. Or air receivers on compressors.
Am I anywhere near understanding what you are talking about? Should there be rum involved?
They are typically pretty big pumps.
At the hull surface, the sea chest typically has some sort of grillage to keep out sea monsters and subsurface junk.
At its upper end, the sea chest typically has a removable (often transparent) cover and a gasket. The top plane of the sea chest should be a little above the static waterline, so that one can stop the engines, stop the boat, remove the covers, and observe and hopefully remove whatever has clogged the inlet grillage, like seaweed, fishing line, fishing nets, scraps of canvas, body parts, whatever.
The sea chest itself should be large enough to supply the raw water pumps for at least a few seconds while the hull surface grillage is temporarily obscured by something sliding along the hull surface while being run over, like an inflatable dinghy, or anything else you can imagine. I do not recall seeing a rule about this; it just seems like common sense.
You should, however, double check the requirements, for instance by scanning the various Rules For Classing Ships, downloadable for free from eagle.org. Allow considerable time, and do use automated tools like the multiple file search function in Acrobat Reader; there is an awful lot of text to look at.
As for the calculation itself, it should be as simple as cross sectional area x vertical dimension, roughly.
Mike Halloran
Pembroke Pines, FL, USA
So those are those things that kept shutting down the catamaran From Seattle to Vancouver when they ran over logs and orcas and stuff. I used to love that - it meant open bar.
- calculate sea water consumption (sea water cooling, firewater, sea water service, watermaker systems) for each sea chest
- find sea chest nominal diameter from the consumption
- check Regulations. Should the unit comply with the latest EPA regulations? Some examples: 1.5 ft/s for common use, 1 m/s for ice class, 0.5 ft/s for EPA. find required open cross-sectional area
- calculate actual open cross-sectional area. Make sure to subtract the grill
- make adjustments and start over
Thank you so much.
Mike Halloran
For calculating the grating and cross over, it has been explained. Please note as per NK and LR, the area of the grating should be twice the area of the cross over pipe.
