NX open version
NX open version
Hello everyone,
I would like to check on which version of NX open the journal is currently running. The reason is simply - from NX9, representation for limits and fits has changes. I wanna change my journals to works on NX8.5 and also on new version. When I use them (from NX8.5) on NX 9/10 they work, but when the dimensions lost associativity and You re associate them, then when You have for example "10 f8" NX automatic change it to "10H7". To prevent this I must check which version is running, and then apply right code.
With best regards
Michael
RE: NX open version
CODE --> C#
string nxVersion = NXOpen.Session.GetSession().GetEnvironmentVariableValue("UGII_FULL_VERSION");Thanks,
Selvaraj Chellamuthu
NX Automation Engineer
RE: NX open version
With best regards
Michael
RE: NX open version
CODE
Dim nxVersion As String = theSession.GetEnvironmentVariableValue("UGII_MAJOR_VERSION") & "." & theSession.GetEnvironmentVariableValue("UGII_MINOR_VERSION")www.nxjournaling.com
RE: NX open version
I try this:
CODE
Dim nxVersion As String = theSession.GetEnvironmentVariableValue("UGII_MAJOR_VERSION") & "." & theSession.GetEnvironmentVariableValue("UGII_MINOR_VERSION") if nxversion > 8.5 then msgbox("YES") else msgbox("NO") end ifAnd I receive error:
CODE
Any clue how to solve it?
With best regards
Michael
RE: NX open version
https://msdn.microsoft.com/en-us/library/994c0zb1(...
RE: NX open version
I have tested this:
- Double.TryParse(Nxversion, nxversion1) -> which return 0 in all cases
- nxversion = val(nxversion) -> which return 10 in NX 10.0 and 8.5 in NX 8.5
- Double.Parse(nxversion) -> gives me an error
- Double.Parse(nxversion), USculture) -> works like val.
- CDbl(nxversion) -> gives me an error
- Ctype(nxversion, double) -> also gives me the same error
- Convert.ToDouble(nxversion) -> gives me similar error
I think the simplest method is val, but I lost trailing zeros. Also some functions which aren't working because of regional settings in system.and finally
With best regards
Michael
RE: NX open version
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.UI Imports NXOpen.Annotations Module NX85LimitsFits Dim s As Session = Session.GetSession() Dim ui As UI = UI.GetUI() Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim nxVersion As String = s.GetEnvironmentVariableValue("UGII_MAJOR_VERSION") & "." & s.GetEnvironmentVariableValue("UGII_MINOR_VERSION") Sub Main() Dim selecteddims(-1) As TaggedObject Dim response1 As Selection.Response = Selection.Response.Cancel nxversion = val(nxversion) if nxversion > 8.5 then start1: response1 = Select_dims(selecteddims) EditDimensionTolerance2(selecteddims) end1: else start2: response1 = Select_dims(selecteddims) EditDimensionTolerance(selecteddims) end2: end if End Sub ' ---------------------------------------------- ' sub to edit tolerance ' ---------------------------------------------- Sub EditDimensionTolerance(ByVal selecteddims () As TaggedObject) Dim markId3 As Session.UndoMarkId Dim dimname1 As String = Nothing For Each selecteddim As Dimension In selecteddims dimname1 = selecteddim.ToString() If dimname1.Contains("Radius") = True Then Dim radiusDimension1 As Annotations.RadiusDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = radiusDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits radiusDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = radiusDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 radiusDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Horizontal") = True Then Dim horizontalDimension1 As Annotations.HorizontalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = horizontalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits horizontalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = horizontalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 horizontalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Vertical") = True Then Dim verticalDimension1 As Annotations.VerticalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = VerticalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits VerticalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = verticalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 verticalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Parallel") = True Then Dim ParallelDimension1 As Annotations.ParallelDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = ParallelDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits ParallelDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = ParallelDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 ParallelDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Diameter") = True Then Dim DiameterDimension1 As Annotations.DiameterDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = DiameterDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits DiameterDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = DiameterDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 DiameterDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Cylindrical") = True Then Dim CylindricalDimension1 As Annotations.CylindricalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = CylindricalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits CylindricalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = CylindricalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 CylindricalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Perpendicular") = True Then Dim PerpendicularDimension1 As Annotations.PerpendicularDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = PerpendicularDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits PerpendicularDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = PerpendicularDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitDeviation = "f" dimensionPreferences1.LimitFitGrade = 8 PerpendicularDimension1.SetDimensionPreferences(dimensionPreferences1) End If Next Dim nErrs1 As Integer nErrs1 = s.UpdateManager.DoUpdate(markId3) End Sub '************************************************************************************************************ '************************************************************************************************************ Sub EditDimensionTolerance2(ByVal selecteddims () As TaggedObject) Dim markId3 As Session.UndoMarkId Dim dimname1 As String = Nothing For Each selecteddim As Dimension In selecteddims dimname1 = selecteddim.ToString() If dimname1.Contains("Radius") = True Then Dim radiusDimension1 As Annotations.RadiusDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = radiusDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits radiusDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = radiusDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitShaftGrade = 8 radiusDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Horizontal") = True Then Dim horizontalDimension1 As Annotations.HorizontalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = horizontalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits horizontalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = horizontalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitshaftGrade = 8 horizontalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Vertical") = True Then Dim verticalDimension1 As Annotations.VerticalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = VerticalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits VerticalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = verticalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitshaftGrade = 8 verticalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Parallel") = True Then Dim ParallelDimension1 As Annotations.ParallelDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = ParallelDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits ParallelDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = ParallelDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitShaftGrade = 8 ParallelDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Diameter") = True Then Dim DiameterDimension1 As Annotations.DiameterDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = DiameterDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits DiameterDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = DiameterDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitShaftGrade = 8 DiameterDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Cylindrical") = True Then Dim CylindricalDimension1 As Annotations.CylindricalDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = CylindricalDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits CylindricalDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = CylindricalDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitShaftGrade = 8 CylindricalDimension1.SetDimensionPreferences(dimensionPreferences1) ElseIf dimname1.Contains("Perpendicular") = True Then Dim PerpendicularDimension1 As Annotations.PerpendicularDimension = selecteddim Dim linearTolerance1 As Annotations.LinearTolerance linearTolerance1 = PerpendicularDimension1.GetTolerance() linearTolerance1.ToleranceType = Annotations.ToleranceType.LimitsAndFits PerpendicularDimension1.SetTolerance(linearTolerance1) Dim dimensionPreferences1 As Annotations.DimensionPreferences dimensionPreferences1 = PerpendicularDimension1.GetDimensionPreferences() dimensionPreferences1.LimitFitAnsiHoleType = NXOpen.Annotations.FitAnsiHoleType.Shaft dimensionPreferences1.LimitFitShaftDeviation = "f" dimensionPreferences1.LimitFitShaftGrade = 8 PerpendicularDimension1.SetDimensionPreferences(dimensionPreferences1) End If Next Dim nErrs1 As Integer nErrs1 = s.UpdateManager.DoUpdate(markId3) End Sub ' ---------------------------------------------- ' function to select dimensions ' ---------------------------------------------- Function Select_dims(ByRef obj() As TaggedObject) As Selection.Response Dim resp As Selection.Response = Selection.Response.Cancel Dim prompt As String = "Select dimensions" Dim message As String = "Select dimensions" Dim title As String = "Selection" Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim selectionMask_array(0) As Selection.MaskTriple Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False With selectionMask_array(0) .Type = UFConstants.UF_dimension_type .Subtype = 0 .SolidBodySubtype = 0 End With resp = ui.SelectionManager.SelectTaggedObjects(prompt, message, _ scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, obj) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleWith best regards
Michael
RE: NX open version
