CuNi 90/10 Pipe inside the tank.
Dear Expert,
Kindly let us know the following questions answer,
1. For Cu Ni 90/10 pipe routed inside the water ballast tank, so what type of joint is suitable & acceptable as per class rule.
2. For Cu Ni 90/10 pipe flange and other material is NAB as per owner technical specification, let me know what is the reason there selection NAB materials for fittings?
Mani.P
Mani.P
RE: CuNi 90/10 Pipe inside the tank.
