galvanic corrosion
galvanic corrosion
Hello, galvanic corrosion usually occurs when 2 different metals in contact, however does it also occurs over same materials with different ASTM code?
For example: saddle and pressure vessel shell connection;
Shell is using SA-516 Gr 70 but saddle is using SA 36.
Thanks!
Thanks!
RE: galvanic corrosion
The same alloy in different HT conditions usually will not behave that differently, especially CS.
