Post-Tension Avg. precompression limits
Can anyone tell me if there is a reference in the ACI code that specifies that the maximum limit of precompression force in a post tensioned slab is 300 Psi (2 Mpa)???
RE: Post-Tension Avg. precompression limits
I have specified over the 300psi several times. Unfortunately I cannot provide a code reference.
But the designer must consider the effect of restraint in the strength and serviceability calculations. This will all depend on the level of restraint to shortening and even the construction sequence and allowance for pour strips to all some movement. Shrinkage and creep effects and temperature change should all be considered as well.
None of the computer software for PT slab design currently considers this fully.
