checkered plate
checkered plate
i have a question. i want to use a 5/6 mm checkered plate under 238 kg/m2 dead load + self weight of checkered plate and 200 kg/m2 live load. it is at pinned from 4 edges long span is 1800 mm short span is 1000 mm. yield stress is 2400 kg/cm2. can i use it under this loads? i didnt find any formulas from books.
RE: checkered plate
RE: checkered plate
Sometimes the easiest solution is the best solution.
RE: checkered plate
