Hole callouts don't work for mirrored holes in nx 9 drafting
When I make drawings in NX I usually try to import the hole callouts for holes I created with the hole tool using the radial dimension tool. Unfortunately in instances where I mirrored holes it won't let me select them with the hole callout feature selected. I can only do inferred which just gives me diameter. Is there a way around this? Thanks
RE: Hole callouts don't work for mirrored holes in nx 9 drafting
-Dave
NX 9, Teamcenter 10
Ryan Lee
Mechanical Project Engineer
NX 9.0.3.12
Aras 11 SP 5
If you can think it it can be modeled
