Help: Export assembly PRT to STP or Parasolid, import with new names.
Here's what I am trying to accomplish:
I'm using NX8.0.3.4
Customer sends us a NX model. It's an assembly of components. What I need to do is create a copy of that model with completely new names in order to modify the model and create drawings as needed. The new names must comply with our company naming convention. Let's say the original model is "123.prt" and the components are "123-1.prt through 123-n.prt"
My current process is to export the authority/original assembly file to a STP model. I will them import that STP model into my template PRT model I created. The new model has the right name. I want them to be "ABC-123.prt" with the components being "ABC-123-1.prt" through "ABC-123-n.prt" for example. However, when importing the STP model, it automatically creates PRT models of all the components, and keeps the original names "123-1.prt" through "123-n.prt" without the desired ABC- prefix in the example.
Without renaming & replacing every single component one by one, or requiring some kind of journal to do it for me - is there a way to set up the default naming procedure NX uses to create assembly components from an imported STP model so that it accomplishes my needs?
I'm using NX8.0.3.4
RE: Help: Export assembly PRT to STP or Parasolid, import with new names.
( I would stay away from Step as long as possible, "Data translation has never added value and never will". )
The Clone assembly will create a copy for you , and it can copy all components into proper names also.
The issue is the drawings, you have to make sure these are loaded into the cloning session, ( else they will not be cloned)
Have a try and respond back if you need assistance.
Tomas
Thank you very much.
If so, this would be a great time to use the master model method (drawing file references the model as a component). The master model method has the advantage of separating the model preferences from the drawing preferences. You could, if desired, use the model files as-is from the customer and your drawings would all be set up with your preferences.
www.nxjournaling.com
It's possible that the best practice solution, given the way NX is geared, is to switch to a MMM. I'll look into that for the next job I set up.
I really wish the boss man would approve my training requisition soon... :)
Regarding the training on this matter,... there is no "NX system management" training sadly.
What you should do , on your and your fellows computers is to set , in the windows control panel, the variable "UGII_SITE_DIR" where the value of the variable should be a directory on a common server. ( example: H\NX_settings\ or: \\servername\nx_settings\ )
depending on you and your colleagues, only you should have write access to this directory, or you and your colleagues.
When this variable is there , NX will in the customer defaults dialog present an option to set "site" settings. These will be saved in that new directory and will apply to everybody who has the windows variable set.
There is a customer default ( for drafting settings only ) which controls if it is the settings in the existing part file which should "rule" or if it is the customer defaults which should "rule". - this options is "slightly" unreliable in that all settings doesn't work as designed but overall it does the trick.
Tomas
I only have a couple of licenses, but I have NX on multiple PC's and with NXcustom I can keep all settings and GUIs consistent.
