Intake temperature vs efficiency
Hi!
Which one of the following two intake manifold conditions will lead to better efficiency, on a spark-ignited engine? Can someone say what is the ballpark efficiency increase between the best and worst condition?
A) 1.5 bar(a) pressure and 100ºC
B) 1.5 bar(a) pressure and 50ºC
Both conditions have the same mass flow.
The story: we are planning on turbocharging a spark-ignited engine burning gaseous fuel. The load is an electric generator working at constant power and speed. The reason we want to turbocharge it is efficiency as well as power increase. We just can't decide wether to install an aftercooler downstream of the compressor.
Is it ALWAYS a good idea to cool the compressor discharge?
P.S. Don't know if this is really important, but the engine works great lean and we will keep it that way. Preliminary testing the selected turbocharger showed that this is OK even in the boosted operation.
- On one hand I remember that all heat engines have better efficiency working on higher temperatures... so if the increase in mass that the compressor will deliver matches the power we want to reach, why bother in cooling?
- On the other, higher inlet temperatures should make the compression stroke more difficult... and we have knock lurking.
RE: Intake temperature vs efficiency
I don't believe you will have the same mass flow (Kg/Hr) of air if the temps are different, but the pressures are the same.
With higher intake temps, the air is less dense at any given pressure than it would be with lower intake temps. Therefore, you need more boost to force the same amount of air molecules into the same engine. That means that you have to apply more force to the turbocharger, which increases pumping losses and heat evacuation from the combustion chamber on exhaust stroke.
How much boost are you actually going to be running?
When you have higher intake temps, you have to push more air in order to get the same amount of molecules into the combustion chamber. That creates pumping losses, and you end up with a less stable fuel and air mixture. (heat decreases stability)
You would have to retard the timing more and/or run the engine with a richer AFR, because the knock limit will be stricter. That will sacrifice efficiency. I don't know which gaseous fuel you're running off of, but I would recommend Natural gas as opposed to LP for a turbocharged generator.
Will it be using EFI or a fuel mixer/carburetor? That matters for IATs
"Formal education is a weapon, whose effect depends on who holds it in his hands and at whom it is aimed." ~ Joseph Stalin
Adding a turbocharger typically increases the mass air flow through the engine, if the turbo is properly sized. So for a given power level, the turbo would allow you to use an engine that's maybe a third smaller than you would need for a naturally aspirated engine at that power level.
It's also possible to size a turbo so that it adds just enough power to drive itself, and sort of loafs along, but what's the point of adding complexity that does nothing? Under that loafing condition, the turbo also doesn't make a lot of noise, and doesn't glow, so where's the fun?
With a working, properly sized turbo, and without an intercooler, you will just melt pistons for no good reason, and you will be down on power, a lot, from what you could get with the intercooler.
Example: I once worked on a boat where the engines couldn't reach their design rpm of 1600 under load, because the seawater-cooled intercoolers (CAT calls them aftercoolers) were fouled with barnacles, so the seawater flow was impeded, so the seawater coming out was too hot, and so was the air going into the engine. I don't know why the CAT techs signed off on them, except maybe because the owner's rep was such a, er, barnacle.
Mike Halloran
Pembroke Pines, FL, USA
Cheers
Greg Locock
Intercooling reduces charge temperature which reduces the tendency to knock which means not as much compromise has to be made with either the compression ratio or the ignition timing or both, and that is on the good side all around. For a given mass flow through the engine, the turbo can operate at a lower pressure ratio, and that is also a good thing.
My friend who did buy one loved it, but soon sold it, because he couldn't keep radiators in it.
Mike Halloran
Euro spec precursor, V6 normally-aspirated XR4i.
My XR4Ti now has an all brass radiator, which is about the least of the extensive mods to which it has been treated; pretty much all performance-enhancing, to be sure. I daresay it gets out of its own way a little better than average, lately.
The higher cycle temps will also increase turbine power allowing you to set up with lower back pressure (larger A/R housing) while running higher MAP both of which reduce pumping loss.
How do you figure the mass flow is the same for your two scenarios? Do you have a throttle downstream of the pressure measurement?
je suis charlie
Fuel: wood gas
EFI or mixer: fuel mixer (actually a "tee", since the AFR here is around 1:1)
unfortunately it knocks if we try to get too much out of the engine, here is a previous post on this same system about it knocking: http://www.eng-tips.com/viewthread.cfm?qid=393108 ... some of you guys will remember it.
I don't believe that the mass flow will be the same either, but I wanted to make the problem easier for me to chew (not a big fan of thermodynamics). I think that you have a very strong point in the above sentences.
And BrianPetersen also adds more sense to the above:
Summarizing, it makes sense to me that cooling the charge in between the compressor and the engine, will lead to less effort in putting extra mass inside the cylinders, it will be less prone to knocking and the operation would be more stable. Makes sense to you all too?
Thanks!
Mike Halloran
No
Yes
No
je suis charlie
Can you please explain why?
2. Agreed
3. Cycle to cycle combustion will be more variable so I would say less stable.
je suis charlie
Whatever method you use to cool the wood gas could be augmented greatly to help you achieve lower IATs and condense water/impurities out of the intake supply. Using wood gas with boost is intriguing.
"gruntguru (Mechanical). . . cooling the charge in between the compressor and the engine, will lead to less effort in putting extra mass inside the cylinders,...."
Guys, adding to the list of negative aspects of intercooling, by cooling the charge we are dumping work that the engine and turbo have expended in pressurizing and heating the charge. The benefits seem to swamp this, but for the engine that does not need the knock reduction and that is not being asked for highest specific power, it appears best efficiency should come without intercooling.
"PV=nRT
Your P and V are the same
n is constant due to constant m-dot.
I think it would be safe to say that your efficiency gain is 50%."
No no no. Very unsafe.
1. You are applying the ideal gas law to what? The compression process only? That will have only a small effect on TE of the overall heat engine.
2. You cannot apply the ideal gas law to determine compressor work in the way that you have tried.
3. T must be absolute temperature - Kelvin in this case - not Celsius.
je suis charlie
Flow losses would only matter ar WOT anyway. At WOT a good intercooling system cooling effect far outweighs the flow losses.
Cheers
Greg Locock
je suis charlie
Changing it to kelvin makes it a 13% efficiency gain from P1,V1,T1 to P2,V2,T2. It's a law of physics so I'm positive that it could hold true. I'm done with this thread.
NERD FIGHT LOL
je suis charlie
a) combustion impacts (which are difficult to predict)
b) air cycle impacts (pumping, compression and expansion work). This is the area than can be estimated, but the model doesn't include them all. (Compression and expansion work, efficiencies, pressures and temperatures would have to be calculated outside the model then fed in)
je suis charlie
