How do AISI 1010 properties compare with c1022 / AISI 1022?
We have a small project in Europe, starting production of Torx screws for timber applications/wood furniture/ like the one in the picture.
We found that most widely imported screws from China use C1022 carbon steel, which should be equivalent to AISI 1022.
However, we have only AISI 1010 (SAE 1010) steel available in the local market.
How are the properties of the two compared, with timber application/wood furniture/ in mind?
RE: How do AISI 1010 properties compare with c1022 / AISI 1022?
But you should be able to look up data and see. You do know the properties of the ones in 1022?
