explosion vs roll bonded clad plate
Could someone give some advise or links on advantage of explosion welded plate over roll bonded clad plates?
All I know is expolsion welded plate, only few people in the world can do it, roll bond is more available from your local shop.
RE: explosion vs roll bonded clad plate
Mike
RB has more limitations on materials, since they must (should) be post-roll heat treated, many combinations do not have compatable HT temperatures.
With either I would require extensive UT to confirm bonding, it is cheap compared to the price of hte material.
