constraint manager: exclamation point with yellow triangle
Using NX 8 I am trying to use a center (2 to 2) constraint and after I select the edges, the parts do not move into place. In constraint manager under status, an exclamation point in a yellow triangle is shown next to the new constraint. The message associated with the yellow triangle is 'referenced objects have been deleted or suppressed'. I cannot find any reason for this issue and I use this type of constraint regularly in other assemblies. I don't know if this could have anything to do with the issue, but both parts I am trying to constrain are imported STEP files that have been saved as NX parts.
Thank you.
Thank you.
RE: constraint manager: exclamation point with yellow triangle
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
