Design of Escalator Pit
Dear All,
May I know what are the factors taken when designing escalator pit?
Thanks.
Thanks.
#LoveWins
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Design of Escalator Pit
Buggar, I was always under the impression that the elevator shops and your pit size on site has to match (within construction tolerances). How much larger can your pit be before the rails etc don't work with their standard hardware?Nevermind, I read elevator, not escalator.
Usually when you design for the wall and the base slab, what load do we take?
Dear Jayrod12,
No problem ^^
#LoveWins
I like to specify lifting loop inserts in the walls spaced around the pit so the mechanics can pull the motors and stuff. I put spare inserts in the corners with spare lifting eyes to replace lost ones. Usually, the money people don't pay any attention to pit details so I like to "fancy them up" for the guys that will be down in them. Also, have the electrical designer run more light fixtures in the hole.
