tensile test simulation
RE: tensile test simulation
I am afraid you will need to digitize such data and place it in two arrays, one for time and one for epstot. Or, if the time step is constant, you can spare it and simply use the array index or whatever.
Other than that, you will need to show what you have so far in the program and how you think you would like to have your imposing strain-time curve.
Thank you for your reply.
If i impose a triangular cycle (figure) i write this:
PARAMETER (pente=1.34d-04,periode=1044.35d0,temp1=522.175d0)
DO WHILE (temp.LE.periode) ! DEBUT BOUCLE TEMPS
IF (temp.LE.temp1) THEN
pendefo=pente
ELSE IF (temp.GT.temp1) THEN
pendefo=-pente
END IF
c Déformation totale IMPOSEE 'depstot'
depstot=pendefo*deltat
but with the previous cycle i don't know how to add the array because 'depstot' must be a real ?
I don't see anything regarding time in your code.
Also, I don't see anything triangular...it looks more like a square wave that goes from +pente to -pente.
I think you need to put together a y=mx+b kind of equation where x is actually time t and y is strain...you need two equations of those, one going up and one going down, etc.
