name the solids and export them as a parasolid file
We had used this journal from cowsky, succesfully even with the NX9
but now with nx10 it doesen't work any more
I there's a possibility to make it work
(note the parasolid file is been created but it doesn't contain name)
thread561-345441: Converting a UG assembly file into a single part file with component names and attributes
Thank's in advance
Thank's in advance
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
www.studiotreccani.com
RE: name the solids and export them as a parasolid file
If you turn the "timestamp" option off, you will see that the solid bodies have the name of the component that owned them. If you want the name to show up in the part navigator when the "timestamp" option is on, you will need to run the secondary journal to copy the names over.
www.nxjournaling.com
