Help. Hydraulic Calculation (water tank)
Hi, everyone. Please help me. My company will not have a hydraulic calculation for fire sprinkler system. because its part of the contractor . is there a way I can estimate or calculate or assume the capacity of the water tank we need to design given that i have the quantity of sprinkler, fire hose, and standpipe? please help me.
RE: Help. Hydraulic Calculation (water tank)
You can also check NFPA 1 or IFC per building construction type.
What about Fire Code of the Philippines?
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
Once you have pump size then you can size your tank based on the time duration required to supply the water.
For example
If you're pump size 1000 gpm and time duration 60 mim (Usually)
Tank size will be
1000x60
=60000Gal
=228m3
