hard to determine the plastic limit
Hi all,
today I tried to determine the plastic limit of an agricultural soil and it was not possible, the thread slipped over the glass plate rather than roll. It was the first time to me that an agricultural soil is non plastic. Is it common? I read that a sandy soil has this kind of behaviour. Tomorrow, I will sieve a soil sample to get the soil texture classification. What is the sand percentage threshold over which the soil is non plastic?
RE: hard to determine the plastic limit
Generally, soils with less than about 15 percent fines will be non-plastic, therefore, soils with 80 to 85 percent sand will be non-plastic. Depending on the character of the fines (type of clay, etc.) the percentage of fines can go higher without being plastic.
thanks for your reply. I tried initially to roll it between my palms and it rolls much better than on the glass plate. The thread breaks into many pieces when it is 1cm of diameter and I feel it happens because it slips over the glass plate. I noticed this soil is not sticky when it is wet and it makes the whole palm brown. Is it a sign of something? It is an agricultural soil, so it will have a higher percentage of fines, I suppose, right?
And agricultural soil can be non-plastic.
Mike Lambert
