FiberSim Error
FiberSim Error
FiberSim Error
I am trying to generate flat pattern layouts from FiberSim 13 but I keep running into the same error: "Could not generate the flat pattern. Check the placement planes." I've tried rebuilding the model, boundaries, etc with no luck. Any suggestions? What are placement planes exactly?
RE: FiberSim Error
fiber sim and catia composites are pretty similar. in catia i use producibility analysis and only then flattening. without producibility there is no way to get flat patterns.
RE: FiberSim Error
I run the producibility before trying to generate flat patterns and it works fine. I see the mesh over the part and no errors are reported. Do you know what "placement panes" are? Thanks for the reply
RE: FiberSim Error
in catia this option is in the flat patterns dialog. upload a screen shoot..again i don't use fiber sim. maybe the program just asks you for a plane for flat patterns
RE: FiberSim Error
It's been several years since I used FiberSim, but I agree with JeniaL that it is asking for the plane upon which to generate the flat pattern.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
RE: FiberSim Error
if producibility goes well there should not be a problem for flattening. upload a picture of flattening dialog.
