Life expectancy
Life expectancy
Hello, can any one tell me how the life expectancy of a pressure gauge increases when you use a glycerine type?
RE: Life expectancy
Likewise, humidity and moisture pose problems for dry gauges. Condensation can make a gauge difficult to read or, in some cases, can cause failure due to icing. Liquid-filled gauges, though, are sealed to prevent internal condensation, and by keeping moisture out of the system, gauge movement is protected during icing conditions.
The choice of fill fluid is based on the application, but glycerin is typically used for room-temperature applications and silicone oil is commonly used for extreme temperature applications, especially when icing is a problem. An oil with insulating properties is ideal if the system has exposed electrical contacts.
http://www.wika.us/solutions_liquid_filled_gauges_...
RE: Life expectancy
RE: Life expectancy
RE: Life expectancy
RE: Life expectancy
RE: Life expectancy
RE: Life expectancy
