Need help to suppress interference in a power supply.
Hello friends, I just modified 110~220v 12V 100 amp JD200 server power supply(from dell poweredge6800) for my high current needs.I had to reroute the AC input from front of the supply to the back.Its working good but i am having strange problem.It works fine during the day but sometimes it shuts down and error led lights up (LED displays over voltage,under voltage,over current or fan error)during night(after ~7-8pm).
I am not an expert and could be 100% wrong but suspecting that interference in the power line is max at that time and because i rerouted the power cord and its very close to the circuit board which monitors voltage and current errors and somehow its tripping the error.Please check the attached picture showing power cord runing close to the daughter board which monitors the voltage and current.
So could anybody please suggest me how to remove interference?Can i use a snapable ferrite core on the ac input cable?Or any other way?Thanks
RE: Need help to suppress interference in a power supply.
Otherwise, a ferrite usually works well. Make it large, put it outside the box and stick the whole cable through it several times. The effectiveness increases with number of turns squared. So, two turns are four times more effective than one turn. And three turns are nine times better.
Gunnar Englund
www.gke.org
Any spec recommendation for ferrite core?Asking because i searched for ferrite core at digikey.com and there are so many factors to choose like inductance factor,material etc.Could you please guide me?thanks
You also might try a higher quality AC cord if you are unsure of the one you are using..
Z
To hold the power entry module,the clamp you see is made out from aluminum and that clamp is connected to the chassis via 2 brass screws.Do you think i still need to try grounding the PEM?I will try to find better shielded cable as you suggested.
One more question, Is it my just assumption or its possible to have interference problems during night time when thousands of electronic devices are running?
Power supplies for computers sometimes are intended to have a minimum load applied when they are on. If you don't have enough load at night that might create an issue.
I'd check your wall power closely and watch for a line voltage step change and see if it's related to your trips.
Keith Cress
Given the symptoms, those signal wires should be separated from the power cord.
Best solution is probably to redo your power cord routing, keeping it away from such signal wiring. Up against the chassis is often slightly better than through the middle.
Dan - Owner
http://www.Hi-TecDesigns.com
Still, should be re-routed.
Especially given the symptoms and the reportedly one-and-only mod from the original design.
It appears there are tabs on the mounting edge of the PEM; that is typically where you need to make good contact and enclosures will be masked in the mate to that area when anodized or painted.
Z
Will try to ground PEM and reroute power cable and see how it goes.
