Odd All-Around Profile Application
Putting this question into words is awkward at best, so please do see the attachment. What is the interpretation of an all-around profile tolerance that controls a part outline where one of the controlled faces is partially represented by a hidden line in the drawing view in which the profile tolerance is applied?
RE: Odd All-Around Profile Application
Now, when it comes to "invisible" profile, at least part of the feature(s) is visible on the view where profile is specified.
According to the the standard, GD&T controls apply to entire feature "unless otherwise specified".
For me it's enough to extend application of profile into "invisible" area, even if it wasn't what creators of "all around" originally intended.
But wait 'til the real experts kick in
The way I see it, the curved part of the protrusion becomes different feature, so profile will stop where the flat stops.
There is also one thing I believe in: if you feel that your drawing may be ambiguous, it is your job to clarify possible misinterpretation, for example, using "profile from A to B", etc.
CH, it sure does "feel" right on some level to say that the hidden portion of the flat surface is controlled, and that anything else is not controlled. I'm tripped up when I try to reconcile the situation where the half-hidden face is not planar at all. What if this half-hidden face is irregularly wavy, for example? See attached.
Are you preparing this drawing, or reading it? If this is your drawing, you can make it more clear.
JHG
But my understanding is, straight or curvy profile has nothing to do with it. As long as the profile is dimensioned, you can put a fence on each side of it. For that mater a lengthwise cross section of a potato could have a profile callout proved every little dip or bump in the outline can be dimensioned in some manner.
In your last examples the face of the lower left iso view that is facing the lower left corner of the page (minus the hole) makes up the profile you gtol is controlling. In effect this would be a top and bottom horizontal line, a vertical line on the left, two short vertical lines on the right, and the bottom horizontal, right side vertical and top wavy portion (with 1.5 humps) is all you are controlling. The hidden portion is not controlled regardless of its shape.
Now saying that, if you gtol was on the top view all it would control is the face of the upper left iso view that is facing the lower right corner of the page (one horizontal line, two vertical lines and a 5 hump wavy line.
Is my understanding way off base???
I only wish the geometry of my part were as simple as the examples I created. I am concerned about creating discontinuities or steps in the profile in question; aesthetics are a driving factor here. My part has radiused transitions between the "friendly" part of the profile and and the problematic part of the profile, as shown in my attached example. I must control any mismatch or step at points X and Y, the tangent points of the radii.
The profiles in question will be milled in house and there with be no problems to speak of no matter what I do, simply because the CNC magic machines are so great.
Anyway, I'm working through it and greatly appreciate all the input!
"The hidden portion is not controlled regardless of its shape."
That very well may be the case. This is the heart of the issue: Is any control applied to the hidden portion?
The whole curved vs. straight business was speculation between me and CheckerHater about how the rule could be applied. My wavy example was meant to challenge our experimental notion that the hidden portion of a planar face was subject to control simply because the visible portion of the same face was controlled.
If the profile controls only the visible portion, that would be OK in my eyes. It would also mean that applying a profile tolerance in such a case would probably rarely be the best option.
Another possible alternative is model based definition. It can allow you to unambiguously specify complicated tolerance boundaries with relative ease, but it's certainly not appropriate for all circumstances. As far as I know, it's mainly early-adopter territory at the moment.
- pylfrm
Your "corrugated" face is NOT a feature, but rather a collection of features. Those not visible are not controlled.
Unfortunately the ASME definition of "feature" is so sloppy, it can be stretched in several directions.
You are the boss of your drawing. You cannot "overstep" anything. There is an uncomfortable thought that you have to take responsibility for the results, but it comes with the profession you chose.
Seriously though, I understand and appreciate what you're saying. I am in a position where great importance is assigned to my opinions, most all of them, including small drawing details. I am a fine engineer, but the great confidence placed in me isn't necessarily all deserved; it's partially because nobody is in a position (knowledge-wise) to challenge me on many issues, GD&T being one. Like many lone engineers at small companies, I must be my own opponent in these debates.
Think of it this way: You find perfect, genius, elegant way to specify the requirement, that only you and couple people on this forum can understand and appreciate.
There is a good chance your supplier may be not satisfied and ask for further explanations.
You mention molding the parts in the future. If you are familiar with ASME Y14.8-2009, it has 2 pages of sample notes one places on the drawings to take care of things, appearance being among the others.
Very often when you feel your symbology is not enough you just create verbal note: this place to be smooth, free of partng lines, ejector pin marks, etc. ("there be dragons"?)
And remember: we never stop learning and our drawings are growing up with us
Good luck!
Anyway, I am so glad to discoverer this Forum. The Posts confirm my understanding of the subject, which I consider a philosophy, as it is a thinking tool more than anything. Applying the controls makes for robust designs that give maximum flexibility to Mfg (read.. lower cost).
Thanks to all who participate in this Forum.
The all-around profile is one of my favourite tolerancing tools. I would still apply profiles to each of your vertical faces.
JHG
(in response to your 10 Mar 16 22:28 reply to me)
... on the other hand if you had put this gtol on a top view (based on the current one being the bottom view) then the tolerance would apply to the basic rectangle plus all (section overhanging plus section on top of rectangular piece) of the wavy piece.
I think, ???
djhurayt, if I'm understanding you, I would disagree. I don't think the fact that the lines are hidden is the deciding factor.
CheckerHater, if I am following you, you'd still advocate that the "hidden" (whether or not they're actually hidden, depending on the view the tolerance is applied in) portions of the partially "visible" FEATURE are controlled.
Is the cylinder in my attached example a single feature in the sense that matters in your analysis? Would you advocate that the entire circumference of the cylinder be subject to the profile tolerance?
I think this latest example distills the issue even more.
I understand completely. From my "teaching" travels at companies in my region, your situation seems pretty normal, which I assume, is why this Forum is so active. My experience: In 1999, after studying for a year, I took the GDT exam and passed with fly-colors. But working "alone" at my company I still had this confidence problem with knowing the material. In 2010 I was fortunate enough to attend a Y14.5 committee meeting where the persons who "evolve" the standard gathered - there names are in the front of the book. Talk about intimidation! After listening to the various topics for three days, I realized I understood everything they were discussing and even had a "opinion" to add (but only Committee members could talk - guests are observers). This really gave me confidence that I know the material. I still buy every GDT book that comes out and read it to get a different perspective. I am now beginning to study the differences between ISO 1101 and Y14.5. Wish me luck.
My reasoning was not because they are hidden lines. But I thought the profile is the outline that is seen on the plane that the view is taken from. Using you most resent example(the one with the cylinder) in the view you have your gtol shown the profile would apply to the two horizontal lines, the vertical lines, and 360° of the cylinder. Where as if the gtol was applied to the view that would be the back side of the one the gtol is currently attached to, then the gtol would be applied to both horizontal line (same), the vertical lines (same), but in this case only 180° of the cylinder.
I say, yes, for better or for worse, the entire cylinder will be controlled. BTW, how would you separate part of cylinder being controlled from part of cylinder being not controlled?
I also say, that if, in your opinion, it is not clear what is controlled and what is not, it is YOUR job to add symbolic or verbal note to clarify your intent.
CH, I don't disagree, and could absolutely accept that interpretation as long as the drawing made it clear. It would be a great way to define shapes like this, assuming you actually wanted the control to apply to the interior surfaces.
As far as separating the halves of the cylinder, that's tricky. Why separate it at all? Can two profile tolerances overlap?
Yes, we can have two profile tolerances applied to the feature and they should be applied at the same time.
BUT even within one profile tolerance the surface may have sharp corners or steps and still comply.
Something to consider
If to the very same view a non-all-around profile of a surface control was added to each of the two partially-hidden surfaces, those controls would apply to the entire respective surface. It's the all-around specification that throws a wrench into the "normal" works.
I tend to agree, on all points, especially this:
Surface profile all-around controls a continuous "true" profile, not a feature or collection of features, or even a surface.
I like to think of it as a "silhouette control", and believe this interpretation is the most robust, meaning the least likely to be turned on its head by a thus far unimagined part geometry.
