Structural FEA Software
Although I have quite a bit of education and background in FEA, the company I work for operates primarily through hand calculations. Recently, my boss has requested that I research and recommend an FEA software that would be a useful tool on our projects. Do you all have any recommendations? I am really just looking for some of the favorites out there to give me a starting place in my research. We do a lot of work with custom shapes (not standard structural shapes from the steel manual) and odd materials (aluminum and glass) so software that can accommodate these items would be most valuable.
Thanks for any insight!
RE: Structural FEA Software
I use it for everything which required FEA--mat footings, walls, plates, and anything else where a simple, linear analysis won't do.
DaveAtkins
Does anyone out there use Bentley RAM Elements? Any thoughts or comparisons with the others?
DaveAtkins
Dave, will RISA 3D check custom sections? For instance, could one draw a custom bent steel section in AutoCAD and then import it into RISA 3D to have it checked for strength (yielding, lateral torsional buckling, flange buckling, etc.)?
If you need something like mechanical parts, complex geometry, or high end results (like non-linear FEA) I'd look at Solidworks with Simulation.
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
Sorry, not trying to hijack this thread but every time I see STAAD(X) mentioned I just have to say something. To make amends, here's some names for you muchtolearn. Robot Structural Analysis Professional, MIDAS/Gen, S-Frame, VisualAnalysis, ETABS, and SCIA Engineer.
You are correct that RISA 3D has that capability, but this statement by JoshPlum suggests that its a pseudo-approach and doesn't consider the non-linearity within the stiffness matrix.
"Remember that RISA is not doing a true non-linear solution for those tension only members. Rather it is iterating a linear solution."
Tension-only members in RISA 3D
I've heard good things about S-Frame; its one of the few structural-oriented software out there that does true nonlinear cable analyses other than GTStrudl and SAP2000.
RAM Elements is definately going to nowheresville.
