how to do the conversion from local grid coordinte line to global coordinate
Hey ALL!
I have to do the some of the setting out work in London site ,,,,but the thing is in my site there are 4 different local grid lines and the value for the grids but unfortunately i have to the setting out but that is not relate any of the the grid line ,,,,, i mean there are no distance from any local grid line to the setting out point ..... so i what i am thing is if i change some of the station value to the global value i can easily set out that points......
so Anyone know how to convert the local coordinate to global coordinate by calculator or any software or app or any online spreed sheet
ply give the answer.
RE: how to do the conversion from local grid coordinte line to global coordinate
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Our surveyors also use some called OPUS (http://www.ngs.noaa.gov/OPUS/), but I'm not very familiar with it. Perhaps the UK has something similar.
BTW, if you need to convert back and forth between latitude/longitude and Universal Transverse Mercator, I posted a worksheet for this on the PTC Mathcad forum a little over a year ago. You can find it here: https://www.ptcusercommunity.com/docs/DOC-6527. The .zip file contains a Mathcad Prime 3.0 worksheet as well as an Adobe Acrobat .pdf file for users with other versions of Mathcad.
--Winston S. Churchill
There appears to be a number of datum conversion programs/sites:
http://twcc.fr/en/#
http://www.mapwel.net/coorconversion.htm
Even Ordnance Survey itself: https://www.ordnancesurvey.co.uk/business-and-gove...
TTFN
I think my question is little bit confused .....my question is
in our site we have 4 different grid lines and the values for them those are not parallel or no connection between them so for the setting out purpose i want to transfer /convert my station ( which is i have in local coordinate ) values to global coordinates ......
Plz if you have any idea plz let me know that ...
TTFN
