Extending Slab on Deck
I have an existing building with a 1.5" deck with 3.25" lw topping (4.75" total thickness). This is a roof over a restaurant and they are expanding the space. I have a new steel frame that will extend this slab by about 12ft (x 30ft in length). The new slab is independently supported vertically and laterally. I have my own new edge beam which will be parallel to and a couple of feet from the existing edge beam.
Question is about the existing slab on deck to new slab on deck joint. There will be an existing pour stop and then my new slab, likely with its own pour stop/closure. The architect is worried that this joint would allow water infiltration into the space if the waterproofing ever fails. This seems like excessive worrying but it is a very high end space and she is really on me about it.
I considered drilling and doweling from existing to new - but is this reasonable in 4.75" of thickness? This would at least keep the joint closed - but she's not very satisfied with that and I wonder if this is enough thickness. Technically it appears so by hilti, albeit with huge reduction factors.
Stitch weld a new closure plate to the existing pourstop and then cast in an expanding waterstop?
Feel like I'm trying to solve a problem that doesn't exist.
RE: Extending Slab on Deck
http://www.cetco.com/en-us/Products/Building-Mater...
With something like that underneath the roofing membrane it would seem that two thing would have to fail for water intrusion, but never say never.
If the existing pour stop is a hot rolled angle, then it's easy. Use a smaller angle for the new pour stop and stitch it to the existing.
I don't think that dowels are out of the question as long as your confident that the differential deflection between adjacent edge beams will be manageable.
It would probably cost a few nickels but another strategy could be tying the adjacent edge beams together somehow to prevent differential movement.
Kootk - I thought about tying them together in this manner but it seems that you'd need a fairly deep member that is moment connected to get any vertical compatibility. Not much space to get in there to work either.
I like Archie's waterstop idea. Maybe dowels + waterstop will calm her down. Thanks
I'd actually intended the left side connection to be a moment connection. A little weld or a 4-bolt group and you've got a 10-15 kN-m moment connection. I think that you only would need a nominal moment connection to smooth out the vertical. If gap control is the only issue, no moment connection would be required.
Sounds as though she could use some gentle re-education. The slab shouldn't be any meaningful part of the envelope.
If this is your intent, then this joint is an expansion joint and needs to be treated that way when waterproofing it. I'd think it'd make more sense to join the elements together, as you seem to be suggesting, and then treat this area as just additional roof that needs to be waterproofed. However, to join the elements together, you will need to "touch" the existing structure to verify it's capability to support this additional mass at the roof.
In either case, this decision is your responsibility and not the Architect's. Once you've made your decision, detail the connection correctly and then tell the Architect to waterproof it correctly (moving expansion joint or just more roof). I rarely say this, but kudos to the architect.
