Seismic Design Category D Connections
I have been asked to design the beam to beam connections and beam to column connections for a new project that is located in Seismic Design Category D. I have review ASCE 7-10 and Seismic Provision 341-10. My understanding is that for the beam to beam connections I can basically use single shear typical connections. but for the bracing I will have to add some over strength factors and make adjustment.
Anyone have any tips? or comments that I need to review. I have never designs an heavy industrial building in this Seismic Zone.
RE: Seismic Design Category D Connections
Get a copy of the Seismic Design Manual. Not just the free AISC 341 available online, but the entire physical book. Go through the examples, they're extremely detailed and step through pretty much everything you need to check for each SFRS type.
In my opinion any structural engineering office doing seismic design of steel structures under US codes should have a copy of this. No exceptions.
Agreed, the seismic design manual was my guide for both studying and during the SE exam. As someone who doesn't do high seismic design in day to day work it's the best reference I found.
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
X3 for the SDM recommendation. Among other things, it's one of the best connection design references that I know of. You can also find some exellent, free information in the NEHRP design briefs: Link
Steeltips has a good example.
Thank you all for your helpful tips. I will get a copy of the physical book. All I had was the free online version.
