CATIA v6 2013x(VBA) Add New Product file and add an existing part in it.
i'm new to v6 automation and have worked in v5 automation.
Can any one help/post some sample reference code to create new product in V62013x and then add an existing 3D part in to the newly created product.
i was able to create a new product and fetch the existing (opened part), but could not able to load the existing part into the new product's root collection.
here is my code:
CODE
Dim oPart As Part
    Dim oPartVPMRepRef As VPMRepReference
    Dim oPartVPMRef As VPMReference
    Dim oProdVPMRef As VPMReference
    Dim oProdRootReference As VPMReference
    Dim oProdRootOccurrence As Object
    Set oPart = CATIA.ActiveEditor.ActiveObject
    Set oPartVPMRepRef = oPart.Parent
    Set oPartVPMRef = oPartVPMRepRef.Father
    Call CATIA.GetSessionService("PLMNewService").PLMCreate("Product", oProductEditor )
    Set oProdRootReference = oProductEditor.GetService("PLMProductService").RootOccurrence.ReferenceRootOccurrenceOf
    'Tried this
    Dim oVPMRepInstsOnRepInstColln As VPMRepInstances
    Dim oNewProdRepInst As VPMRepInstance
    Dim cListRepInstancesColln As VPMRepInstances
    Dim sRepInstanceName As String
    Set cListRepInstancesColln = oProdRootReference.RepInstances
    sRepInstanceName = "I_" & oProdRepRefToInstantiate.Name & "." & cListRepInstancesColln.Count + 1
    Set cListRepInstancesColln =cListRepInstancesColln.Add(sRepInstanceName, oProdRepRefToInstantiate.Parent, oNewProdRepInst)  ' -- Not Works
    ' Error : Add Method of VPMRepInstances Failed
    ' And also This
    Dim oVPMInstancesOnInstColln As VPMInstances
    Dim oNewProdInstance As VPMInstance
    Set oVPMInstancesOnInstColln = oProdRootReference.Instances
    Call oVPMInstancesOnInstColln.Add(oPartVPMRef, oNewProdInstance) ' -- Not Works
    ' Error : Add Method of VPMInstances Failed
Please let me know how to proceed.
Maddy
RE: CATIA v6 2013x(VBA) Add New Product file and add an existing part in it.
yes, Ferdo,
Scenario is like this (CATIA V62013x)
I need to create an assembly from opened 3DParts and i have 2 part files opened
1. Part1
2. Part2
I created a new product Product1 (Assembly - through program)
Now i need to add Part1 and Part2 to Product1 (New Product)
And then put a constraint (contact constraint) between Part1 and Part2
Hope it is clear now.
i'm facing error while instantiating Part1 (VPMReference) onto Product1's Root Reference
i followed the way API described (oProdRootReference.RepInstances.Add and oProdRootReference.Instances.Add) but not works.
Don't know where doing i'm wrong
Maddy
