Regarding Intersection curve
When I create an Intersection curve between two datum planes, an error comes up. I have attached the snap of it. Is it because the planes are of infinite length? Please explain
RE: Regarding Intersection curve
and the reason is as you say, since the planes are infinite , the line will be cut by the screen edges and therefore non associative.
There is nothing in the part which defines how long and where on this vector the line will exist. Two planes only defines the vector.
If you replace one or both of the planes with a face, it will be associative since the length and position then has a definition.
Tomas
