I have a BS and MS in math. Want to become a PEng. in Canada. BEng or MEng?
I am a math professor from the US. I have a bachelor's and master's in mathematics from a US university. I desire to change careers from a mathematician to an engineer (mechanical engineering). I am immigrating to Canada and would like to get an engineering degree at a Canadian university, and later get work and a PEng license in BC.
I would like to make the most efficient use of my time and money. Is it necessary to go back and get another bachelor's degree in mechanical engineering, or could I just get a master's degree in mechanical engineering? And if a master's, should I get a MEng or a MAsc? I want to take the best path to a job and later a PEng in Canada.
(Please note that I have asked a couple of Canadian universities and they said that I would qualify for admission to either program even though I don't have a bachelor's in mech eng.)
RE: I have a BS and MS in math. Want to become a PEng. in Canada. BEng or MEng?
These links might be a good place to start...
http://www.apega.ca/apply
https://www.apeg.bc.ca/Become-a-Member
Steve
Cheers
Greg Locock
It would be possible, strategically, to select courses at a large enough university to satisfy this requirement, without actually needing to know much in the fundamentals of any particular engineering discipline.
At my uni, most of the 4th year courses are dual-certified as grad courses- and some of them are very, very easy to pass.
Many take an M.Eng. for that reason- if you go to a large enough school and take long enough to complete the degree such that there's sufficient course selection, you can get through without having to work very hard at all.
The regulatory bodies are onto this. It is a strategy used by foreign-trained engineers to avoid taking the extensive fundamentals exams that are otherwise assigned- or at least, it was a strategy that they used, until the regulatory bodies put an end to it. No matter- you don't need a license to practice here anyway, as an employee engineer anyway.
An engineer repleat with math but without the underlying physics and chemistry and related disciplines in an engineering context, is not really an engineer. I'd be far more satisfied with an engineer who did all those fundamental courses but didn't go beyond high school calculus, honestly. Not that the math courses are all useless- but most of the instructional time IS wasted, trying to get the students to the state of the art of mathematics circa the year 1700 or so.
I too have met plenty of people who function quite well in a limited engineering practice without a complete education in engineering fundamentals. Some people learn extremely well on the job. But without the grounding in fundamentals, it's tough for me to consider them on par with a graduate of an undergrad engineering program who has gained a similar number of years on the job.
I work in a very mathematical field, yet most of what can be usefully done could be done with (UK) high school maths and amazingly fast computers. The major exceptions for me are statistics (another parlour game- based on one good piece of maths and a lot of crossed fingers, which I suspect can be entirely replaced by Monte Carlo simulations), and Fourier analysis, to which I know of no simpler alternative.
Cheers
Greg Locock
At most I used linear / polynomial interpolation but still with Excel and rules of thumb. At the end I am wondering what use I really made of the university program. Diploma to me was just an entry ticket and had nothing to do with the show itself. Some other people may relate to this or just tell us what their experience is, i.e. how far they did use the tools and math gained at school in order to do the real stuffs?
Steve
I barely did any new maths in my first year at university having done Maths & Further Maths (Pure & Applied) at high school/A-level, I think it was my highest graded subject and I spent almost no time on it expect maybe matrices. Made up for it a bit in the second year and think we'd covered Div, Grad, Curl and all that before the folks on pure math degrees.
Taking advanced aerodynamics - or could have been considered as all the fancy math approximations/algorithms of Navier Stokes equations that don't quite work in practice - then built upon my increasingly jelly like mathematics foundation.
Being on top of the math should really help you so long as you're not one of the rare folks that's a whiz at equations etc., but can't correlate equations to real world situations.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Not necessarily. Junior and senior year are supposed to have upper division courses that are same as the one the MS candidates take. A typical MSEE is a 1-yr program, which contains classes that aren't part of the typical BSEE course load, since the BSEE program at my school included a Technical Seminar Presentation and Written Technical Communication as well as project/thesis and humanities classes
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
https://www.apeg.bc.ca/Become-a-Member/How-to-Appl...
Regardless of the requirements for licensing, I would say you should really aim for a bachelors. It's where they teach you the fundamentals of engineering. I have no idea how you'd get real value from a masters without the fundamentals of things like statics, dynamics, material science, thermodynamics and similar things. If you did manage to select a path through a masters that you could succeed at, you'd either be doing a significant amount of study outside of the degree, to the point where you'd be learning the bachelor's material anyway, or you'd graduate without the necessary breadth of knowledge to actually function as an engineer.
Talk to the local universities. You might be able to reduce the number of courses you need to take significantly, given your existing qualifications. Hopefully, you could talk yourself out of the first year general courses and all of the math.
I feel like the people who are saying that they don't use their bachelor's degree are underselling the amount of context and understanding of fundamental information they got out of it.
Do you know what you want to do as a mechanical engineer?
Yes, junior year as I recall - at least that's when we started the topic.
Ditto in US, if you are took AP Calculus. If not there, then either freshman or sophomore year in college. Junior year in college was for AMa 95, Introduction to Complex Variables (Shwartz. Other DE related material was taught in an EE class for Intro to Fourier and Laplace transforms.
TTFN
Granted, to put this all in context, probably less than 5% of the math I do daily involves any of those subjects.
For mechanical engineers, have you guy studied "error functions" (i.e. "erf") ?
This was prompted long time ago by a discussion I've had with a lecturer on the subject of the validation of numerical methods.
Typically what you see in technical publications is people comparing numerical methods and derived results against a set of data already available (verified empirically or even analytically thru simplification) and when it is matching, it is supposed to be validated...BUT according to this lecturer (a very sharp guy) validation is a pure mathematical approach consisting in finding a range of upper / lower bounds to variables. In other words, the validation consists of proving that the numerical method leads to a solution that is always bound within a certain range which is demonstrated analytically. To do this you need some very sharp math and error functions is one of the things which was mentioned to me (I guess not taught in engineering class).
Thus my question, how familiar are you with this (off) topic of error functions?
Speaking of statistics, it was not a required class in my, but you can learn more than enough to get you into trouble. Unless you are doing bleeding edge research, that level of rigor is grossly unnecessary.
TTFN
TTFN
Not only was that a bit rude miningman, it was also inaccurate.
I double-checked on the APEGBC website, and though a brief review does not reveal whether or not they have a C of A program like Ontario, I confirmed what I said to the OP earlier: you DO NOT need a license to work as an employee engineer- you merely need to work under the supervision of a licensed engineer. Ultimately, to get a job, the only person you have to convince you're able to work as an engineer is your boss- unless you want to hang out your shingle and provide services directly to the public, in which case you likely ALSO need a C of A as well as a license (again I haven't confirmed that's the case for BC but it certainly is in Ontario).
As to the modestly off-topic conversation, it certainly didn't bother me. Perhaps you were having a bad day?
"Once you get registered in one province, transferring is easy."
That is why, in the eighth post, I provided the links to the APEGBC *and* the APEGA websites. Alberta is the closest Province to BC, and an appreciable number of engineers and geoscientists who are licensed in one Province are also licensed in the other. Indeed, work is often done on both sides of the border, so that the only true complication really becomes making sure you don't pull the wrong stamp out of the drawer when you're about to issue something. Well, that and making sure the stamp isn't upside down...but let's not go there. Actually, some of the stuff that I do lately is dual-stamped for use in both Provinces, and I am seeing more of that ever since the requirement to have the signature and date applied on the APEGA Permit To Practice stamp was replaced by the requirement to simply state the Permit Number in the title block.
Per miningman's post, thus, it might be easier to get licensed in Alberta and then follow up with an application for licensure in BC on the strength of the former. I know in my particular case 20 years ago, it was certainly easier to do it that way.
Ergo, it was not only TLHS who provided useful advice, it was also miningman.
One thing I will say, though, is that the review of application for licensure tends to be case-by-case, so an individual is never sure of exactly what requirements will be imposed, and I personally have seen variations in this regard over the years with people who have undergone the process. The best thing to do is apply and see where that leads, after they have had the time to assess your academic credentials and work history. What they end up imposing on you might not be the same as for someone else.
