Ventilated Cable Tunel
Good Day!
I need some Technical Data and guidance about Ventilated Cable tunnel for Power cable. Kindly recommend.
Asad
RE: Ventilated Cable Tunel
Do you mean tunnel or tray. Tray is as described in the link by mcgyver.
A cable tunnel may be the passage way joining the turbine hall in a hydro power plant with the transformer yard.
A cable tunnel carries the cables from the generators to the Generator Step Up transformers. The cables may be installed in cable trays in the cable tunnel.
A cable tunnel in a mine mill may carry the cables from the substation to the main switchgear, and from the main switchgear to the various individual transformer/PDC combinations. The cables may be carried on cable trays in the cable tunnel.
Bill
"Why not the best?"
Jimmy Carter
If you intend to calculate the current carrying capacity of power cables in tunnels see:
The Current Carrying Capacity of Power Cables in Tunnels by B. M. Weedy; H. M. El Zayyat
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&a...
Power Cables and Their Application, Power Cables and their Applications: Part 1 (Power Cables & Their Applications) (Pt. 1) 3rd Edition by Lothar Heinhold .
http://www.amazon.com/Power-Cables-Their-Applicati...
pp. 230 Ch. 18.5
