Abaqus wear subroutine
Dear experts;
I want to do a wear simulation incorporating the UMESHMOTION subroutine.
I have tried the simple model to model the wear in Abaqus, but I still stuck to produce wear and get the wear volume. I want to try the simple geometry.
The idea is , a rotating cylinder is loaded onto a flat surface so that this will give the contact between two body.
Then will generate wear on the surface. Maybe from your experience you can help me. Here I attached the the file related
the subroutine
http://files.engineering.com/getfile.aspx?folder=3...
Model .cae
http://files.engineering.com/getfile.aspx?folder=1...
http://files.engineering.com/getfile.aspx?folder=b...
I really hope the experts here can solve my problem. Thank you
the subroutine
Model .cae
RE: Abaqus wear subroutine
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
http://eprints.nottingham.ac.uk/10681/1/ThesisFina...
Here there is a code for the subroutine. Everything is carefully descripted. It is a great work.
If you are starting to use UMESHMOTION, I advice to you to start with a plane strain/stress model wich is more efficient.
Higlights for wear that I remember:
- The mesh should be very refined to reproduce correctly the hight concetrated gradient of stresses. You can check the mesh convergence with the Hertz contact formulas.
- You can only access to the slave node data using the subroutine.
IceBreakerSours (Bioengineer). Thank you for the replied. I use Archard Law for the wear and Hertzian contact .
Yes, this is my first post and my first time joining the forum.
rrg1016 (Mechanical)
Thank you for the information. I ll try it now.
