86 Relay TX Protection
Silly question:
I have no more NC contacts from an ABB RXMBV4 RK251401 relay to block close 2 more feeder breakers (a deficiency from the project before me).
I've read literature that suggest you can change the contact stacking from NO to NC. But i've no experience doing this. Has anyone heard of this before? Or is basically ordering a new relay the only option available? Also, would you replace the existing 86 relay with one with more NC contacts? or would you connect it in series with the existing one?
I appreciate your responses, thank you.
RE: 86 Relay TX Protection
Thank you sir!
http://new.abb.com/substation-automation/products/...
