Partial Bolt Circle and View Scale? NX9
A user here created a partial bolt circle using a center point and 2 holes. Works great. He then changed the scale of the view, and dimensions to the bolt circle changed. The radius was different as well as the angle between the holes.
It appears the associativity to the center point gets messed up when view scale changes.
Thoughts?
Thoughts?
RE: Partial Bolt Circle and View Scale? NX9
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
One of the most favorite quotes of Gtac is that it will be resolved in version "X" :)
Tried to reproduce it in NX9.0.3 mp9 but I couldn't. Might be my model isn't build the same as yours...
Also couldn't find anything on Gtac about it...
Can you upload an example?
NX9 / TC10.1.2
HP Zbook15
