Seam pipes in building application
It is mentioned in our company document to use electric-resistance welded pipe i indoor application for fire fighting, but when i use NFPA 13, i found that it is applicable but with ASTM A135 while my document say that it should be A53.
note:
the connection i grooved not welded for sizes larger than 50 mm.
thanks in advance.
note:
thanks in advance.
RE: Seam pipes in building application
