ANY HELP ON THE AREA CALCS ETC ON ADDING A 4" NOZZLE TO A VESSEL - NEW TO THIS
THE DRAWING IS RIDUCULOUS FOR ALL THE AREAS INVOLVED TO CONSIDER
HAS ANY OF THIS CHANGED WITH THE 2015 VIIID1 EDITION?
ADDING A SCH 40 4" SA106GRB NOZZLE SET FLUSH WITH THE I.D OF THE VESSEL.
VESSEL IS .365" WALL THICKNESS - STILL SA106GRB MATERIAL
STRESS VALUE 20K?
E =1
RE: ANY HELP ON THE AREA CALCS ETC ON ADDING A 4" NOZZLE TO A VESSEL - NEW TO THIS
No, it is basic and has been in the code for years.
What areas would you suggest they not consider?
Nope, not 20K for SA-106B, more like 17.1 up to around 650 F.
Mike
Toddy-
STOP SHOUTING. It gets tedious and makes your post irritating to read.
How 'bout you get a mechanical engineer to perform the mechanical engineering evaluations? Better yet, one with the experience and judgment required in order to meet the intent of the Code. You have read the Foreword, right?
