CSIBridge/SAP2000 : Error in reading section cut results.
Hello fellow engineers,
First of all im a French student so i dont know the exact english words for the technical terms i'm about to use.
Im a student working on a final year projet which is a bridge with 3 modules (3 continuous decks, I Girder),
lets say for example i have 2 Load Patterns(Charge Fixe + Charge Amovible), once i launch the analysis i can show the results of the 2 Load Patterns, but the problem is once i choose to show the Combination result (lets say : 1*Charge Fixe+1*Charge Amovible) i get this error "Error in reading section cut results".
I've looked online, sap2000/csibridge manuals but i can't find the slighest clue on my problem.
I've taken some screenshots of my problem, Thanks in advance !
RE: CSIBridge/SAP2000 : Error in reading section cut results.
I would guess that there might be a unit difference in the 2 graphs. Looking at the graphs, they're identical in shape, but it appears that the magnitude is different looking at the Min/Max values.
Hello, thanks for taking time to read my problem and answer me, really nice of you.
both the units are kiloNewton, metre, celecius,and yes both the graphs are identical in shape, however their values are way different,
Graph1: Max=12882,989 & Min=-13566,04
Graph2: Max=5285,9821 & Min=-5614,83
