Enforced Displacements
Hi Everyone!
I'm facing a bit of a challenge that I would like to share with you.
I need to apply enforced displacements on many nodes (nearly 1000), I manage to isolate them in a group, and the value of the displacement to apply is a factor times the node coordinate.
So the issue is: how do I ask femap to apply these enforced displacement on each node!!?
I try a function, but does not seem to work, so I try to figure out a clever way of doing it, but I haven't found one yet!
Of course I will not manually create individual load on each node with the enforced displacement value...Hope there is a solution to this problem!!
Thanks for any idea you can bring on the table!
RE: Enforced Displacements
I made this code, try to use...
Sub Main
Dim App As femap.model
Set App = feFemap()
'---Create a Load Set
Dim Load_Set As femap.LoadSet
Set Load_Set = App.feLoadSet
Load_Set.title = "Load Set - Test 1"
Load_Set.ID = 1
Load_Set.Put(Load_Set.ID)
'---Create a load that will be applied at node
Dim Load_Geom As femap.LoadGeom
Set Load_Geom = App.feLoadGeom
Dim Load_Defi As femap.LoadDefinition
Set Load_Defi = App.feLoadDefinition
Load_Defi.dataType = FT_NODE
Load_Defi.loadType = FLT_NDISPLACEMENT
Load_Defi.setID = Load_Set.ID
Load_Defi.Put(Load_Defi.NextEmptyID())
'---Create a set that will store your nodes
Dim Set_No As femap.Set
Set Set_No = App.feSet
'----Create a object node
Dim No As femap.Node
Set No = App.feNode
'----Two Options
'1) Select your nodes manually
Set_No.Select(FT_NODE, True, "Pick your nodes")
'2) Select your Group
'Set_No.AddGroup(FT_NODE, **THE ID OF YOUR GROUP**)'---Put the ID of yours group in the second parameters
'---Looping for each node to get the position x, y and z
Set_No.Reset()
While Set_No.Next <> FE_FAIL
ID = Set_No.CurrentID
No.Get(ID)
Pos_x = No.x'---get the x position...
Pos_y = No.y'...
Pos_z = No.z'...
Load_Geom.geomID = No.ID
Load_Geom.type = FLT_NDISPLACEMENT
Load_Geom.setID =Load_Set.ID
Load_Geom.ZOn = True
Load_Geom.z = Pos_y * Pos_x
Load_Geom.Put(Load_Geom.NextEmptyID())
Load_Geom.LoadDefinitionID = Load_Defi.ID
Load_Geom.Active = Load_Geom.ID
Wend
Woo I'm impressed, thanks a lot for taking the time to write such a code! I'll have a deep look at it, I'm sure it will be very helpful!
Cheers!
