304 and 316
304 and 316
304 and 316
Dear Friends,
I have to procure a metal hose with core A182 TP 304 but the manufacturer is offering A182 TP 316. I believe 316 is better than 304. Please advise
RE: 304 and 316
316 has added molybdenum. It is more corrosion resistant and generally is considered an upgrade.
RE: 304 and 316
And the mechanical properties are very similar.
Unless you are using 304 for some very specific reason the swap to 316 should work fine.
