Macro to make parts from a generic design table
Hi All
I am trying to figure out how to read data from a design table and apply it on an existing part(not built with a macro). imagine a bolt, that I have put the letter Dh for the head diameter in the dimensioning , and in the design table I have indicated different Dh for different designs. how should I apply these values to the parameter Dh in the part using a Macro ?
RE: Macro to make parts from a generic design table
You need to parse the excel (either using the Excel APIs or preferably via the ODBC/OLED source for the performance reasons). Then you can use this method to apply parameters: Configuration::SetParameters.
Artem
LCform,
If you have your data in a design table, you can easily select the version you want at assembly time. You can select multiple versions of the part for the same assembly. Why use a macro?
Can you enter your tabular data into the design table, and make a selection from there? This results in part, albeit, an easily re-configured part.
What are you trying to accomplish?
JHG
exactly what you said before drawoh, just since all the configurations are not saved as part, and only there is one, but I have to edit it every time for other configurations and copy and save them in another folder, but I dont know the method you mentioned , how is it done ?
LCform,
You can model a part with multiple configurations, and select a configuration at assembly time. For example, you model a cap screw. You create a configuration for each size and length. You insert the screw into your assembly. You change the size of the screw by selecting a different configuration. You insert another screw, and you change the size of that by selecting another configuration.
JHG
