How do I create lines in drafting without having a dimension showing?
The blueprint I'm creating needs to have a line between two datum features, but all I can do is do a linear dimension for the line BUT I don't wan't the distance between the two points displayed. It's not in any of the options to hide the number. I know I can create a curve on the print, but it doesn't have the arrows, like the dimension line does. Nx 8.5
RE: How do I create lines in drafting without having a dimension showing?
I've done this instead of editing the value in a dimension. We have to run a Checkmate program when submitting drawings for approval and it will flag an edited dimension. Then I just create a note to say what I want.
Mike
This will likely raise a flag if using Checkmate, but should work otherwise if I am correctly understanding your situation.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
