Unwrap conical helix strip
How can I unwrap a conical helix in inventor sheet metal ???
http://files.engineering.com/getfile.aspx?folder=9...
I need to develop by sheet metal so that when I can use it in flat pattern.
Please suggest me if anybody know/ guide !!!
RE: Unwrap conical helix strip
Take a look for some suggestions within the attachment:
http://files.engineering.com/getfile.aspx?folder=e...
I'm weal at sheet metal- Particularly in flat pattern.
Please share some screen shots for flattening the shape.
I tried to represent that coil of sheet, but never saved. Sorry. May be later I'll make it again.
Inventor makes flat pattern automatically and it is very easy single button pushing.
When you'll done with the Sketch and Coil in the 3D Model Ribbon, return to Sheet Metal Ribbon and simply press Flat Pattern (not available in Inventor LT) button.
Be sure your coil thickness agrees to the Thickness on the Sheet Metal Default.
Regards.
But revert when you finished the same.
I need some screen shots of the same operation you DID!!!
I'll try to share with you a movie how to make it. Enjoy and sorry for the low resolution as I am not expert of screenshots and movies maker.
http://1drv.ms/1RboW55
I want to develop:
[1] Equation curve in inventor
[2] Incorporate equation in excel
[3] How can I develop the formula like reducing amplitude?
