Maximum plastic strain for low carbon steel ?
Hi All
I have a low carbon steel wire , 1033 , which when I applied a tension test on it , and from the force displacement curve I got the true stress-strain curve , but I wonder why the maximum strain that I have got is 0.14 , in which as in the test , the wire breaks, but in standards and some other resources , I see this material has a maximum true strain of 2 , to calculate the true stress - true strain I have used all the instructions that is in every related source :
true stress = eng stress*(1+strain)
True strain=ln(1+eng strain)
RE: Maximum plastic strain for low carbon steel ?
Try this link
http://academic.uprm.edu/pcaceres/Courses/MatEng30...
That link has exactly what I did ! no I did 3 samples, 3 diameters, but in all of them I have calculated the max true strain low, not close to 2 , would you tell me, what could be the reason ?
I think on page three of the link it shows a graph of true strain and engineering strain, so assuming I am not misunderstanding what I read the true strain appears to be an ideal theoretical case but because of work hardening within the material and other flaws or inclusions the strains don't quite match.
http://www.srmuniv.ac.in/openware_d_loads/u10lect%...
the problem was from my side , i am sorry , I had written LOG instead of ln in excell
