Portal End Plate
Portal End Plate
Portal End Plate
The steel fabricator has stopped the rafter end plate of a portal 5mm shy of the rafter bottom flange so the endplate doesn't extend beyond the column stiffener plates.
Any thoughts on this?
John.
RE: Portal End Plate
I think it's fine. I wouldn't mind seeing a sketch though to be sure that I understand the situation though. I'm assuming a bolted joint.
Yeah a sketch would be helpful because my first thought was how the weld to the flange/plate is constructed.
Will send photo from site tomorrow. Thanks. John.
I got it sorted, thanks guys.
John.
