Sketch Origin in Active Sketch view
Hello all,
Does anyone know, when I create a sketch in the active sketch view on a drawing, at what z coördinates the sketch is created? (assuming the view is a topview of X-Y plane)
We have a drawing with a section cut where the sketch (section cut view is active sketch view) disappears if we set the back clipping to a certain value. When I disable the back clipping the sketch appears again... The value where it disappears doesn't seem to be connected to the z position of the section cut on the parent view...
Unfortunately I cannot share the drawing publicly....
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: Sketch Origin in Active Sketch view
Sounds like a good question for GTAC.
www.nxjournaling.com
Did you try checking the view using expand Option and see those skecthes in view to check their position?
Shetty,
Using NX 10.0.1.4
Quote (cowski)
Contacted GTac indeed...they checked...The "Z-coordinates" seem to be totally random. The clipping values where the sketch disappears even change on different machines...
They have raised an ER for this...they see the value of being able to control this with associativity....
For those interested..
ER 7656095; Desc: Allow the user to set the z-depth of a sketch created within a drafting view.
NX9 / TC10.1.2
HP Zbook15
