Building bridge curve using knowledge fusion
Hi every one!
Recently I've started to use knowledge fusion. I used nx help as tutorial. Now I have a tough task for me: to build a bridge surface between two faces. I adopted this faces to KF and tried to built a bridge curve first.But stack with start point attribute. I understood that KF needs coordinates for the point, but I have only faces and edges from them, so I tried to refer to the edge end point, but it causes syntaxes error.How can I describe this point using this edges?
Thank you.
