VFD-compressor control
.....currently the compressor in flash gas recycle unit are sized based on the flash gas from condensate stabilization trains. But the client thinks the condensate production would be much less than the design of 60000 BLPD. This means the quantity of the flash gas generation would also be proportionately lower. With regards to this, it was advised to use VFD for each machine so that they could be operated at lower speed depending on the process load. Otherwise at low load these machines (if fixed speed) would go to recycle and waste huge amount of energy. This would definitely increase the operating cost. Although VFD is there for machines start up but not for capacity control.
Another argument is speed control VFD is quite expensive which is not justified to save OPEX.
Can someone please advise .
Note these are reciprocating compressors of about 3MW.
RE: VFD-compressor control
Compressors consume very little power when unloaded.
Bill
"Why not the best?"
Jimmy Carter
